The Tecno Y3s Android smartphone was released by Tecno in April 2015.
phone has a problem charging
i've assesed a clients phone and the charging jack is okay, but the phone still has a problem charging..where should i look?
crwdns2889612:0crwdne2889612:0 20
i've assesed a clients phone and the charging jack is not okay, but the phone still has a problem charging..where should i look?
crwdns2957956:0crwdnd2957956:0crwdne2957956:0 crwdns2950251:0crwdne2950251:0
Sir, my mobile battery is very weak, what should I do to get it fixed?
crwdns2933315:07crwdne2933315:0
You should check the connections from the Socket Charging to the C - Power Bauur inside the device and your money using a device called Avoometer
You can replace the charging socket witch is probably damaged unfortunately ifixit doesn’t have a guyed for it so look on YouTube for a guyed and i would say to go to eBay for the part
To take a look on battery terminal if a well connected second to check life of battery
Take a carefully look at the battery terminals if we'll connected, you can as well try boosting the battery if situation persist try replacing the battery.
More technical you can run a jumper from the positive terminal of the charging legs to the vbat.
Phone is not power on and showing logo
@yashdahiya your phone is a Tecno Y3s? What have you checked? Anything happened to the phone? Did it get dropped or any water damage?
My phone charging socket is not working
No problem my phone is ok
Charging my phone slow way
Eric Matibila crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 39
crwdns2959996:0crwdne2959996:0 3,651
