The fourth generation of Honda Accord covering model years 1990 through 1993 available in coupe, sedan, and wagon chassis.
A/c compressor fuses and relay located
On an 88 honda accord where are the fuses for the a/c compressor and the relay for it located on the car
@dtingey77
you’ll have to check Fuse #5 which is the fuse for the clutch relay. The clutch relay should be in the engine compartment on the left fender behind p/s fluid reservoir. There should be two relays. One is for the condensor and the other one for the a/c clutch.. The one with a red wire on the connector is for the AC.
Danielle. Tingey crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 5,105
