printer blue light flashing but not working
printer blue light flashing it dose the startup sequence but nothing els and the touch screen is off
Hello,
I have an Epson XP-800. When I power up, the power button lights up but the screen never comes on.
The power light blinks once every 10 seconds or so, but I cannot see what the problem is.
Help!
Thanks
hi turn on printer then unplug the power source then click each printer release button but don’t take them out.
this may be hard if the cover is over them but still possible.
plug back in and wait it should tell you that the cartridges are not installed
then click all back in good luck
regards rik
That worked! Thank you
Thank you so much, this worked for me today the 04/04/2020.
My XP 960 had the same problem and this fixed it. Thank you loads.
thank you. Worked for me too
Brilliant - worked like a charm. Thank you.
I have this exact issue, did you resolve it?
Fantastic just saved my bacon printing my daughters wedding invites it worked as you said
ok try this, take the power lead out of the back of the printer or turn off from the mains.
then open the lid and release each of the ink cartridges, you may have to use something fine like a small screwdriver as it will be in the docked position, you don't have to take the cartridges out.
plug back in and power up at this point it should come back on, good luck
My printer is so 760 and I have the same fault
It works also with the XP-760 . Try it!
crwdns2942667:0crwdne2942667:0 6,182
solved my problem
regards Stu
crwdns2934271:0crwdnd2934271:0 stuart cawthorn crwdne2934271:0
Thank you very much; it worked.
crwdns2934271:0crwdnd2934271:0 Bestoon Omar crwdne2934271:0
Fantastic. Many thanks as this worked for me.
crwdns2934271:0crwdnd2934271:0 mageric crwdne2934271:0
