Repairing Breville TG400 Sandwich Maker
When I insert my toaster to the plug the electricity at my house goes down. I’m sure that it is easy to fix that problem. I opened the toaster and everything looks fine. Maybe the plug itself is the problem? Should I replace it?
If it is blowing the circuit breaker by just being plugged in, I would replace the plug in cable first.
You might also want to clean some of the dirt on the pins.
Also what else is on the same breaker line you maybe overloading the circuit.
What is the breaker or fuse rating for the outlet you are using.
Eden Bensal crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,238
