The Dewalt DCD771C2 is a compact, lightweight, high performance drill released in September 2013 whose usage is ideal for projects around the house.
DeWalt lithium ion 18v issues
Hoping someone can help me out here I have 4 x 18v li ion batteries 2 of which are 5 months old & 2 which are 8 months old. When at work the other day one of the batteries ran out so I put it on charge to discover my other 3 were also flat, after charging all 4 batteries until the charge complete light came ON I went to use them to find that they all went flat after about 5 seconds of pressing the trigger on the drill so I then tried these batteries in other cordless tools such as my impact driver with no luck.
 I tested each battery with a multimeter and each battery had between 10-11 volts.
 I find it hard to believe all 4 batteries would die on the same day so I stuck my multimeter in the charger and although the 'charging' light would not flash the charger was out putting pulses of between .5 - 3.5v DC, is this normal?
 Does anyone know a method of pinpointing the problem? Eg battery cell test or charger test?
I had the same problem! What I was doing wrong was I didn’t push the battery hard and far enough on the charger. When battery is inserted properly you will feel it click into place then the battery will truly charge.
crwdns2889612:0crwdne2889612:0 7
Guy - Thank you from Florida. I read your answer and it works!
Yes worked thanks, needs a fair bit of muscle to force the battery onto charger. I am always scared I might break something using that much force!!
Sometimes you feel so stupid ? thanks for the answer
Thank you so much! I knew it had to be something i was doing wrong! Why isn't this made clear in the instructions?!!!
Drillbatterycomau crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 5,346
