The Ninja Coffee Bar CF080 brings espresso creations to your home with the press of a button. Born in 2016 by Ninja, its Auto IQ 1-touch intelligence allows for custom and signature brews. With convenient pod-free single serve.
Why is my Classic Brew button not working?
I have a Ninja Coffee Maker and the Classic Brew button does not function when I press the button.
I have this problem with the model # CF082, 2 years old and the Classic button plus the clock and delay brew doesn't work. Very disappointed in a higher end brand and machine.
This is incredibly dumb but it worked for me. After cleaning it multiple times with no luck, I found that if I set a delay brew function with the time set to NOW+1 minute, it works just fine.
Yes this worked, seems it gets stuck on the timer, so once you retime it, the brew light goes on as soon as it hits the time.
This worked for me!! Thank you!
This did not work for me because I have to select the brew type when setting delay brew and the new button doesn't function for this either.
I've actually had this issue for years now and occasionally it works after unplugging it for long periods of time. I have back up coffee makers that I bring out when it's not working and try plugging it in every day or so until it's working again. This last time it worked for several months without issue. And now here I am again. lol
I think it is a design floor, I believe it is not sealed properly and water leaks in and reeks havoc with the controls
My ninja will clean just fine but will not brew for nothing. I’ve tried all the buttons, with no luck. I have un plugged it. I’ve even open it to see if there’s a clog in the pipes still not working
This is the same issue I’m having!
@gatlin77 this is the same issue I’m having and for the money they cost I can’t believe the quality is terrible like this. I had a coffe mate pot for 10yrs and it still worked when I gave it to goodwill!
I agree that the issue is likely water infiltration. But, one thing I noticed is that the buttons that don't work are brew settings that also turn on the hot plate. If the hot plate is shorted from a spill, could it make the whole brew selection fail? I'm leaning this direction because it seems that a simple unplugging for 5 minutes does not fix it for me. It has to be unplugged for 30 minutes to a day in my case which may be how long it takes things to dry out.
That's my issue too! It cleans but doesn't brew no matter what size or strength I chose
I went to call the customer service number and they told me there is no way of fixing it. Instead they told me that they can send a new unit for a $156. I was disappointed . Kohls is even selling it for $99.
I have a ninja dual brew XL an it doesn’t brew clean cycle doesn’t work correctly keeps going to clog
I cleaned it an tried to reset no luck
I got the classic Brew to work by unplugging the unit waiting for a few minutes and then plugging it back in while pressing the button at the same time.
Need to try this myself. anyone else have luck with this trick? OP has the problem gone away or came back?
Mine went out a couple of years ago. Everything else works but the Classic brew and the minute button. It did come back on, out of the blue one day but that didn't last too long before it went out again, never to be seen anymore. I just gave up. and moved to the next brewing button. If too strong just use less coffee. So far my Ninja food processer works perfectly. (A gift)
I changed my setting from 9 oz to 11oz and now I set for 11 and it starts then,goes to clean and I have not been able to use.
Phil Merlino crwdns2934231:0crwdne2934231:0
crwdns2936751:024crwdne2936751:0 15
crwdns2936753:07crwdne2936753:0 95
crwdns2936753:030crwdne2936753:0 346
crwdns2942667:0crwdne2942667:0 21,510
