A portable, rechargeable jumpstarter that can provide instant jumpstarts for cars and trucks.
Road master power station
I have a roadmaster power station it is been in my trunk dry and not exposed to the weather and went to go use it and the battery is dead I tried to plug it into the AC outlet and it does not charge what can I do
Try plugging it in and leaving it for a night, then, try using a different power cord, if it takes AC directly.
Sometimes you have to sort of “push and pull” the cells to get them to start taking a charge again.
sealed lead-acid batteries are practically bullet proof.
but if nothing works, gotta crack it open, and change the cell - find a electronics parts store’ - they will give you a reasonable price for the battery - Also remember you can sometimes join 2 batteries together to make the final voltage you need, if you want to Frankenstein it. like if it needs 12v - and you can only find two-6v cells, as long as the amperage is the same or more then they can be joined using a pigtail, i did this for mine a while ago. BUT you would need to read up on doing that properly to not cause a meltdown.
errrrr, you can check the fuse with a meter :)
Howard mcfadzen crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 382
