Repair guides and support for Panasonic's Viera line of televisions.
Panasonic Smart Viera TV no red standby light won’t switc
My electricity popped on main switchboard & TV went off, there’s no red light showing for standby. This isn’t the 1st time this has happened as TV has long spells of not being used. In the past your suggestions have worked perfectly but unfortunately not on this occasion!
Have retried your advise ie unplugging / holding standby button on back of tv for 60 secs / Holding both volume & standby button on back of tv for 60 secs / Checked fuse etc to no avail. Was hoping to have a lazy Sunday in front of TV but don’t think that’s gonna happen!! HELP
Thank you so much….
crwdns2944067:04crwdne2944067:0
How do I put my Panasonic Viera TH50PX70A on standby. Can only switch on by power button on TV.
Hi @pete0404pete ,
If the TV is on, try pressing the Power button on the TV to turn the TV off.
This should place the TV in standby mode.
Standby means that the power is connected to the TV from the wall outlet (which is on) but the TV has not been switched on using either the power button on the TV or the remote control.
The power LED on the front of the TV is red in the standby mode indicating that the TV is ready to be turned on and green when the TV has been switched on. If it is red and then it doesn't turn on when the power button is pressed on the TV or the remote is another matter ;-)
If the remote control doesn't turn on/off the TV, have you checked that the batteries are OK?
If so use a digital camera (a mobile phone camera will work) to test the remote is working.
Point the end of the remote that you normally point towards the TV at the camera lens and then press and hold any button. You should see a light flashing at the end of the remote when looking at the camera's LCD screen.
If you see no light at all try another button or perform the test using a known working remote control unit to ensure that you're doing it right.
Try pressing other less used button on the remote first rather than the Power button, CH Up/Dn or the Volume Up/Dn buttons. to prove that the remote is working, as these buttons are the most used and may have literally been worn out. (the contact material on the underside of the button that is)
Once you have proved that the remote is working try the Power button etc and check if they also are working OK.
If the remote works OK but doesn't turn on/off the TV ensure that the IR receiver window (bottom left front below the screen) is not being blocked by something. After that it may be a problem with the IR board in the TV
How do I on my panasonic viera Tc-L32c3 from standby without remote
No red light does not always indicate a catastrophic event. My Panasonic 42” plasma will do it if the power goes out. Sometimes take a days for it to come on. No blown fuses, all power strips and wall outlet good. 120v going to power board, but 0V at the voltage regulator. Its strange.
crwdns2933315:06crwdne2933315:0
Hi @asap911 ,
Try using the controls on the TV.
Press either the Power button or if that doesn’t work perhaps the Menu button.
Here’s a link that shows the TV controls for your model TV
The key here is that there is no standby light at all. This is usually an indication of some type of catastrophic failure of the power supply. It might be as simple as a blown fuse given that you said that the power “popped”. Check that first. The fuse should be easily located. Change/check that first and update this with the results. If that does not resolve the problem, post a picture of the power board for starters and we’ll provide additional info and instructions.
Dan
Hi Dan, Many thanks for taking the time to reply to my plea!! I’ve checked fuse for the TV plug but that’s ok. Interestingly the TV remote doesn’t illuminate & I’ve changed the batteries but it still doesn’t! Have taken pic of main board but don’t know how to post on this page….
thanks again
andrea to post images you have to attache them to your question. Use this guide Adding images to an existing question for that. You also need to tell us what exact model your TV is
Hi @cacornett58 ,
What is the model number of the TV?
The standby power light coming and going indicates a loose connection or a poor connection (dry solder joint?) that may be affected by temperature perhaps i.e. cold contracts- no connection, heat expands - good connection. It doesn't take too much to make for a poor connection.
The low voltage signal from the power board to the mainboard that power is available so the standby LED would be on, could be disrupted as the voltage (5 -11V DC) can't as easily overcome the possibly higher resistance connection as would 120V AC.
You may have to check if there is a service manual available online for your TV and hopefully that is has a schematic of the power board so that you can initially trace back the standby power circuit.
Just search for Panasonic (insert full model number) service manual to hopefully find results
My Panasonic Smart TV went into standy mode and refuses to on. I have tried every buttons on the remote and even switch off the TV from the power socket for 5mins. The standby mode will turn to green when you on and immediately go to red light after a minute. Pls, i need a help urgently.
Mine does the same thing as soon as a fuse is blown around the house. Leave it for a few days without it plugged in this is important and then try. I usually leave it for 4 days any sooner and the power switch won’t reset. It seems as though all power needs to be drained before it resets the surge power switch.
Hi,
Try disconnecting the power and then holding the TV power button operated for a full 30 seconds before releasing it. Then reconnect the power and see if it turns on etc.
By holding the power button operated you are forcing the TV to try and turn on. It can't of course because there is no power to the TV but what this does is that it drains all the residual power in the TV.
Also try connecting the TV's power cord via a plug in surge protector (example only) which is connected to the wall power outlet as this may lessen or even prevent the problem from happening in the event of a blown power fuse or even a blackout etc
On the back of my tv is a button on the right side as you are facing the screen. The red standby light was off and the moment that button was touched the tv came on. So try checking the buttons on the back of the tv.
Hi
I’ve had the same problem. Suggest the following.
1) unplug tv and then Re plug in after 2 mins
2) turn tv on via the power button on the back or side of tv
3) remove batteries from remote control
4) press the red power button on the remote for 30 seconds
5) press all buttons on the remote control (while it has the batteries out!)
6) replace the batteries and try using the remote
andrea crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 45
crwdns2936753:030crwdne2936753:0 155
crwdns2942667:0crwdne2942667:0 16,255
