backup lights, mirrors, electric windows, not working, also stick is l
I was installing a back up camera, suddenly, backup light stop working, transmission got locked in parking gear, mirrors, windows, ac compressor, signal lights stop work as well,,,,does anyone know wich relay is damaged and its location?
@heccxon how and where di you try to install the camera? Did you tap into any wiring harness etc? I do not think it is as easy as a single relay. To many things have stopped working that are not on one relay nor are they related. Post some images of anything that you may have cut to splice etc. Post those images with your question so that we can see what you see. Adding images to an existing question
Remove the battery cable and leave it off for 15-30 minutes. Then reconnect and see what happens. Make sure that you have your radio code (if needed) before doing this.
hed crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 62
