high pitch sound when play button is pressed
when play button is pressed down there is a high pitch sound, when the volume button is turned low it disappears and then when on high it is a high pitching noise.
This is a common problem that is usually resolved by cleaning an internal multi-bank switch. The problem is a feedback loop that is caused by dirt/debris inside the switch which connects a couple of circuits that should be separated. Open up the unit and spray all switches with a lubricating electronics switch cleaner. Engage the switches multiple times and the problem should be resolved.
Dan
crwdns2942667:0crwdne2942667:0 2,629
My cassette deck emits a high-pitched squeal as soon as it is turned on, without a tape installed and in play mode. Any thoughts on the cause of this?Thanks.
crwdns2934271:0crwdnd2934271:0 Ian Pattison crwdne2934271:0
