The Gateway NV52 was released in 2008. It is similar to the MS2274 and NV5207u models.
Why is my laptop turn on but not the screen?
at first its wont turn on at all, I opened it, put it back together, now its turn on but not the screen, and once the screen was getting very hot, I have turn it off and power back on again, and the screen still not come on
connect your system to external display if its working there must be a fault with display, will reply once you execute the step
If the fan is spinning when you switch on the laptop and no display this could be a problem with the memory. Try taking it out and putting it back and also if you have 2 memory cards try with one. Try connecting to a monitor. If it works on a monitor the problem is with the inverter or LCD cable.
If it does not work with a monitor what could be the problem? fix?
minh thien crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 593
