LTE-enabled variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
Antenna and Bluetooth options
Is there a difference in Antennas between Wifi and LTE Ipad 5? I need to replace the bluetooth and Wi-Fi antennas for an Ipad 5 LTE(at&t) but i can’t find the parts for it. Any help would be appreciated thanks.
Hey malcolm
I believe the Wi-Fi and cellular antennas on this model iPad are one. On both sides of the iPad’s frame on the inside you will see two antenna leads that power the device. The Wi-Fi and cellular are both network bandwidth connections so these should be the same. The Bluetooth antenna is data related this is an additional antenna in the frame of the iPad usually seated by the front panel camera.
Hope this helps good luck!
hello ,,
i want to know which one is Wifi antenna and Bluetooth antenna ,
 thanks .
malcolm crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 172
