Bosch SHU34C wont stop running
It gets down to 1 minute left in the cycle and it wont stop running. When I open the door, the bottom of the washer is full of water.
Cause 1
Drain Pump
The drain pump uses an impeller to force water through the drain hose. If the drain pump motor is not working, the dishwasher won’t drain. To determine if the drain pump is defective, check the pump motor for continuity using a multimeter. If the motor does not have continuity, or if is getting power but won’t run, replace the drain pump. Drain pumps are not repairable—if the drain pump is defective, you must replace it.
Cause 2
Drain Impeller
The drain impeller pushes water through the drain hose and into the garbage disposer or drain line. If the impeller is broken, replace it.
Cause 3
Drain Solenoid Kit
The drain solenoid opens the drain valve to allow the water to exit the dishwasher. If the drain solenoid fails the valve will not open causing the dishwasher not to drain.
If I push rinse and hold it will drain. Any thoughts?
Yuck. Are you getting any error codes? Let's see if we can get @ladytech to help.
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 3,131
