Remington PG 6050 USB port needed for replacement
Remington PG 6050 , quite old model, not too expensive, but because water corrosion and I guess bad build quality the usb port of the razor is broken.
USB 'pins' are broken when I tried to clean them. The charger should be fine.
I took ik apart and it's quite an easy replacement with an soldering iron, but where to find the part?
See below images.
https://imgur.com/a/kxrPQIH
