Welcome to the Fast Fix project page! The Fast Fix project is part of iFixit's University Technical Writing program. This project is all about quick and simple fixes for household items like bikes, guitars, toys, and more. If you are a student looking for more information on the Fast fix project, please visit edu.ifixit.com and click on the "Fast Fix" project type.
How do I get out a completely stripped out Philips screw from laptop?
I have two Philips head screws on the shell of my laptop, I got one out with ease and the other I could not get out. I tried and tried, I tried using different sized screwdrivers, using a rubber band, and other methods and through all of this the result is a completely stripped screw. I would like to remove it so I could swap out the hard drive before college. Thank you for your help.
Hi @zworm ,
You could try drilling the head of the screw off with a drill bit the same width as the head.
You only have to drill down far enough to remove the head. Once the head is gone you should be able to lift the cover over the remaining shaft of the screw and then remove the rest of the screw using a pair of pliers etc and unscrewing it. You’ll obviously have to replace the screw with a new one.
Be careful when you remove the cover that no “swarf” (bits of metal) falls back into the laptop. Use a vacuum cleaner to suck it up before lifting the cover
Do not drill down too far and drill through the part of the cover that the screwhead rests on. Also drill straight as again you don’t want to ruin the access hole to the screw etc.
Use a drill on the slowest speed possible to prevent too much damage if you slip etc.
This may be a bit drastic but it does work. Maybe practice a bit beforehand on a screw that you’ve screwed into a suitably sized hole in a block of wood etc.
Zachary Wormstadt crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 492
