Ho do I stop my pogo from spinning
I can't just jump facing one direction because the pogo stick keeps spinning to the right and I can't stop it
Hi @smallniko ,
Can you stand on it from the other side, i.e. so the left foot is placed where the right foot was (and the right where the left was ) and you're facing the other direction?
If so does it still spin to the right when you jump?
Does the spring look twisted "at normal" so that when you push it down it then twists back when it comes back up forcing the rotational movement?
@Swagington 35 ,
If the coil looks twisted or "spirals" around the stick, when the stick is not being used it means that when it is compressed when you push down, it will twist the stick (rotate) as it restores to its' normal position, spinning the stick (and the user).
The coil should be straight up and down around the stick so that when it is compressed it goes straight down and pushes straight back up again and doesn't twist the stick as it pushes up.
Hopefully this is a bit clearer.
Hi,
I had the same problem. The pogo stick kept spinning it drove me nuts. thanks for the help !
Hi I tried this and all it did was make spin right and then left when before it spinned left and then right
I have no idea what u mean someone plz help me
Can someone please explain how to actually fix the problem , no matter what side I stand on it still spins?
Hi @Gamerai Gaming,
As suggested above does the spring twist around the shaft or go straight up and down when the pogo stick is at normal i.e. not in use?
If it is twisted then it has to be released from how it is being held on the shaft and then repositioned so that it is straight and then reconnected to the shaft so that when it is compressed it will just spring back up in a straight line rather than twisting around
You are right swiginton35. The bottom lock stop is out of line. It is high on one side from a hard stop by a heavy person. I have the same unit as in the picture. If so, just a hard stomp on the other side should fix it. Design defect.
crwdns2942667:0crwdne2942667:0 1,880
Mine keeps turning right and then when I try to turn left it spins left help me
crwdns2934271:0crwdnd2934271:0 Drew Atkins crwdne2934271:0
