An Android smartphone announced by vivo in July 2016. It has a larger screen and battery, and a higher-resolution camera compared to the base X7.
crwdns2934591:08crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Got my phone wet for almost 10hours. Volume up is already grounded
Sorry my phone is Vivo V7+
Got my phone wet for almost 10hours. Volume up is already grounded. It is going to fastboot mode when i open it. Any suggestions on how to fix it or should i take it to a service center? Thanks.
My phone is not working
Hi @jhay19
As you know liquids and electronics and electricity are not a good mix.
The liquid causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components. The corrosion process starts immediately and continues until it has been cleaned properly
First do not turn on your phone and then you need to remove the battery as soon as possible from the phone to minimize further damage.''
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ (available at most pharmacies) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and is not as effective. If you do check the label to verify the amount of IPA
Here is a link that in general, describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a video showing the teardown of your phone, which may be of some help.
If this process seems too daunting, take your phone to a reputable, professional mobile phone repair service experienced in water damage repair and ask for a quote for a repair.
If you decide to do this, do it sooner than later.
Jhay crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 509
