Why is my laptop screen going blank?
My laptop screen went out and now its all just dark screen. The battery is fully charged and I can still power it on and log in. But then the screen just went out. Please help!!!!!!!!!!!!!
Hi @sasres
Just verifying that the screen works when you go to login (splash screen and Windows startup screen etc and then it goes black after login, is this correct?
Connect an external monitor to the laptop and check its display is OK or not
What OS is installed?
If you have Win 10 installed try starting the laptop in safe mode and check what the laptop's display is like.
I had the same problem. Tried restarting in safe mode, but the computer shut off again. I tried resetting windows 10, but the laptop shut down before completing the analysis. I was away for about 10 days and I left the laptop unplugged. Once I plugged it back in, I have been able to use it. I'm suspecting a battery problem may have been the cause. So far it hasn't shut off after two or three hours use.
Please my problem is, I’m having a faulty battery so after putting my charger inside the laptop when I try to start it the power button on for sometime and goes back off without seeing anything on the screen…
Can anyone help please
do this
1. open the task manager and (ctrl+ shift +esc) look for windows explorer
2. and right click on it open file location and hit enter on the explorer
3. wait a few seconds for the explore and desktop manager to launch
and when u can acess the pc… update windows immediately ..
Hi @mpsoha ,
If the screen is just a dark screen, how can you can "see" what you are doing?
Hello @sasres !
It looks like a software related issue. I will recommend you to boot your machine into recovery mode and try to restore your system from its last restore point.
For example, by default windows 10 automatically creates a restore point before you make any changes to the system settings or install or uninstall a program.
Just google how to boot your machine into the recovery. I can suggest you to disrupt the boot process as many times as you can (for example - turning off the machine forcibly while it loading the system). This should bring up the recovery window.
Then you get to the recovery (Windows 10) you’ll see a blue screen - Select Troubleshoot - Advanced options - System restore. You’ll see the list of available restore points. Look at the dates and choose the point when the system was functioning normally and try to restore.
If your Lenovo IdeaPad shows a black screen on startup before reaching the desktop, see the Lenovo IdeaPad U530 Touch Shows Black Screen on Startup problem page for possible causes and solutions.
sashaomwere crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,031
