Toshiba C55t-A5222 wont turn on
My laptop won’t turn on. The Adapter is fine, the battery is fine. Its charging, the led for charging is solid white but theres no led light showing up for the power. I tried removing the battery and plug and pressing the button for 30seconds-1 min and plugging it back in but it still won’t work.
Try unplugging the battery and turning it on with the battery removed. In some situations, the battery itself will prevent the computer from powering on.
If that doesn’t work, try reseating the RAM module(s). If there is more than one, try starting it with each one individually.
There are numerous things that can cause this type of issue, it’s just a matter of running through each of them to find the culprit.
Roxy crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 617
