How To Fix 3E Samsung Washer Error Code:
1. Unplug The Washing Machine:
Unplug the washer for 2-3 minutes. If the fault is displayed because of an electronic glitch, or communication issue, unplugging the washer for several minutes may possibly reset the electronic panel. Make sure to leave the washer unplugged for at least 2-3 minutes. Leaving unplugged for that long will allow the capacitors located on the printed control board will discharge. letting the capacitors completely discharge is the best way to reset these electronic control boards.
2. Check Wire Connections On Drive Motor:
One fairly common issue that causes the 3E error code is connection problems. Double check the wire harness on the motor. To do so you will need to remove the small back access panel to see the motor and connections. On the back right side you’ll see the motor and the motor wie harness. If this was my call I would remove the connection and check the inside of the molex connection. Sometimes the contacts inside the contain burn/melt. If that check good examine the first several inches of the wire as it leaves the molex connector. I’ve seen the wire break a couple inches away several times. I’m not sure if it’s from stress or friction but I’ve seen it a couple times so double check that.
3. Check Wire Connections On Control Board:
The control board could possibly have a faulty wire connections or loose connection. Not very common at least not in my area but it could happen so It’s worth mentioning. Double check each connection on the control board. Make sure each connection is tight and the wires are not pinched are burnt anywhere. Again if this was my service call I would remove each wire one at a time and plug back in making sure each wire connection is seated tightly. That just ensures everything is good and sound and one more thing is ruled out.
4. Check Hall Sensor:
The hall sensor on the back of the washer monitors the speed and direction of the tub. The sensor can be out of range or it could also have a faulty wiring connection. I’ve also seen the wire harness on the motors hall sensor break. I know of other technicians who have seen the same issue. Double check the hall sensor. If you have a multimeter, you could ohm the sensor out. You can ohm the sensor out from the board or directly at the sensor. If you tested the hall sensor from the board, that would rule out a broken wire at the same time. That’s usually how I test these hall sensors. You don’t have to slide the unit forward and you can test it from the front.
Finally if all the above test good. The motor is going to most likely need to be replaced to fix the fault code. The motor on these units are actually very reliable. Unfortunately a few of them most have made it out of the factory with issues because the 3E error code on Samsung washers is becoming more and more common. I used to see this code very rarely. In the last two months I bet I’ve seen it 3-4 times.
Did you find this article helpful? Do you still have questions about your Samsung washing machine error code? The 3E fault code can be fixed and I can help you. If you still have questions, use the ASK Matt tab at the top of this page or the comment form below.
Answer thanks to Matt
Video on fixing it:
https://www.youtube.com/watch?v=_H6EDquj...
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
6
crwdns2944067:07crwdne2944067:0
Can I still wash if I am seeing the 3E error code???
crwdns2934271:0crwdnd2934271:0 Tg Ytbarek crwdne2934271:0
Why isn’t anyone talking about the drain pump causing this? Is that possible? If the “fins” on the drain pump can be an issue…why can’t the pump not operating be an issue for the E3 code? Tks
crwdns2934271:0crwdnd2934271:0 Gregory Tripp crwdne2934271:0
Thanks for sharing. I also experience this issue with my Samsung 16KG.
What I did was that I switched it off and on many times, but no positive change.
What I did again was to empty the drum, set the machine to spin and I paused the machine, then opened the and turn the drum clockwise, close the drum again and release the pause.
That is all I did to restore the spinning and 3e error code.
crwdns2934271:0crwdnd2934271:0 Olayinka hakeem ishola crwdne2934271:0
Hello, I have been battling a 3e error on my Samsung washer. I have replace the hall center, no change. Replace the board in the rear and that worked for a month. Then went again, thought it was a bad board so brought another one, good for another 3 months then went out again, decided to swap out the rotor and another board, still nothing. Finally called a repair guy and he said they would have started with everything I have done . They advised wiring harness. The guy said if that’s not it, something went faulty and time for a new one. Just installed wire harness today and fingers crossed.
crwdns2934271:0crwdnd2934271:0 Kurt crwdne2934271:0
I had the same problem ... the filter in the front for the evac pump had a penny, a nickel, lots of calcium and lint like material.. cleaned it with vinegar and she is bow working like a new one ! Just lower access plate unscrew to the left. I had to line filter up to replace. Clockwise ofc!
crwdns2934271:0crwdnd2934271:0 Waylon Thomas crwdne2934271:0
crwdns2934275:02crwdne2934275:0
