Grass is normal, why do the blades slow down after I begin cutting?
Grass is normal height as always, when I begin to cut the blades slow down at times almost stopping while engaged. Tention is on belt. I even turned belt over. I have not changed the belt since having the mower, 6/2016.
I replaced the filter and it continues to do the same.
crwdns2934271:0crwdnd2934271:0 Cedric Watson crwdne2934271:0
You might have contaminated gas in the mower. Drain out the old gas. Change the fuel filter. Get new gas, non-ethanol if possible. Mix in some Seafoam gas treatment with the new gas. Fill your tank with the gas/Seafoam mixture. Now crank the engine. The Seafoam will clean out your fuel system. If the problem was with the fuel system, then the Seafoam will solve your problem.
https://seafoamsales.com/small-engines/
crwdns2934271:0crwdnd2934271:0 MrJimPhelps crwdne2934271:0
What would gas have to do with it? My blades slow down too but not the engine speed my belt also has tension on it.
crwdns2934271:0crwdnd2934271:0 Kevin crwdne2934271:0
