Which SSD disk is compatible with Mac Mini Mid 2010
Dear All,
I would like to replace the original hard disk for a SSD.
I have found the following SSDs and would like to know if they are compatible. I have phoned Samsung but they referred me to Apple.
  • Samsung 860 EVO 250 GB 250GB 2.5" SATA III
  • Samsung 860 EVO 500 GB 500GB 2.5" SATA III
  • Samsung 860 EVO 1 TB 1000GB 2.5" SATA III
Is there also an instruction available how to replace the disk?
Kind Regards,
Rob
Here’s the IFIXIT guide you’ll need to follow to swap out your drives: Mac mini Mid 2010 Hard Drive Replacement. At Step 21 you’ll need to take the thermal sensor off, use extreme care! As its very easy to break. Transfer it to your SSD in the same location. Do take the time to read some of the comments before you start.
As for your choice of SSD’s: The Samsung 860 EVO line is a great drive. In truth it runs at all of the SATA speeds: SATA I (1.5 Gb/s), SATA II (3.0 Gb/s) & SATA III (6.0 Gb/s) we call these drives ‘auto sense’ as it will match up with your systems SATA Port I/O speed. Not all drives do this! So you picked a winner here as your system is only SATA II (3.0 Gb/s).
I’m not sure I understand you listing out the different drive sizes its upto you what your needs are. Depending on which version of system (2010 Mac Mini’s (Macmini4,1) you do have a second choice. As an option you can add in a second drive using this kit: Installing Mac mini Mid 2010 Dual Drive replacing your optical drive. Or, if you have the server version then this kit: Mac mini Dual Drive Kit
That way you can keep your current drive and then after installing your MacOS onto the SSD as well as your User accounts & Apps switch the boot drive over to your new SSD. Leaving your HD as the data drive for your stuff. That way you can reduce the size of the SSD you need.
crwdns2886500:0All the hardware needed to a second hard drive to your 2011 or 2012 Mac mini.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$26.99
crwdns2886500:0Mac mini Mid 2010 Hard Drivecrwdne2886500:0
crwdns2930805:0crwdne2930805:0
crwdns2934079:0crwdne2934079:0
crwdns2937801:0crwdne2937801:0
55 minutes
crwdns2886500:0Mac mini Mid 2010 Dual Drivecrwdne2886500:0
1 - 2 hours
crwdns2944067:09crwdne2944067:0:
Thanks a lot
I ordered the SSD
Rubber cement is mentioned. What is it and do I need it for the thermal sensor?
Kind Regards,
Rob
Where do you see rubber cement stated? Are you sure you didn't mis-read rubber grommet.
Use this guide to completely replace your mini's hard drive. Completing this guide requires rubber cement to stick the old thermal sensors to your new hard drive.
Kind Regards,
Rob
OK, I think I see where you see that. That was someones note. No, you don't need rubber cement. There is some sticky tape wrapped around the wires. Just don't over handle the stick parts and you'll be fine.
Thanks,
I received the disk and have started. But I am stuck at 12 One 26 mm T6 Torx standoff don't know how to remove it. Don't have the correct tool or something. And there it looks like there is not enough space to remove the disk. Hmm what to do...
crwdns2934275:04crwdne2934275:0
I have also purchased (Sept 2019) and installed a Samsung 860 EVO 500 GB 500GB 2.5" SATA III into my Mac Mini Mid 2010.
The original system drive (5400rpm 320GB drive Toshiba MK3255GSX from apple) has been running really slow, like 4-10 MB/s read/write speeds. The link speed has also negotiated at 1.5Gbps so maybe even though the Toshiba MK3255GSX is Sata 2.0 there might be a bad cable.
I installed the Samsung 860 EVO and booted off a High Sierra USB, and the disk utility can’t even see the SSD :(
I’ve re-seated the cables, but nothing.
Put the original drive back in and the system booted up fine, but is still super slow and negotiated to SATA 1.0 link speed.
I’ve read all the other comments from Dan about swapping SATA cables; but I can only find “original” SATA cables for my SATA 2.0 capable chipset (based upon the screenshot 3Gbps link speed listed).
If I’m going to find a correct cable for the default HDD on the Mac Mini Mid 2010, which one is it - that will work with my SATAIII drive (that link negotiates as per Samsung Spec) on a SATA 2.0 controller?
So far - no working Samsung 860 EVO on my Mac Mini Mid 2010; and looking into firmware updates but it’s not so simple when the Mac Mini is my only machine with the Optical Drive.
Edit 27 Oct 2019: after replacing the SATA Cable with a SATA3 one specced for a Mac Mini 2012, diskutil command line showed the SSD, and then it was able to be formatted by Disk Utility and a restore of time machine kicked off.
Maybe it's just like the issue on the MBP2010's where someone needed to swap the SATA cable from that model for the cable from the 2012 model like @danj has posted in numerous other answers and comments:
Will the Samsung EVO 860 SATA III SSD drive work in my system?
I have a feeling since my original MacMini HDD is negotiated at SATAI link speed, the cable can only handle that. Thus I reckon the Samsung 860 EVO tries to negotiate at SATAII which the chipset can handle, but the cable isn't up to it.
This MIGHT mean I should use a replacement SATA Cable from the newer Mac mini models, instead of just replacing the original with like for like incase it's damaged (which it may or may not be) as they supported SATAIII (6Gbps): https://everymac.com/systems/apple/mac_m...
Given the fixit one is out of Stock I ordered this one which is same size as the Mac Mini Mid 2010 lower HDD and same connector orientation, and specced for the Mini 2011 and 2012 (Sata 3.0):
https://www.ebay.com.au/itm/New-Hard-Dri...
I'll fit it when I get it and see if it detects the Samsung 860 EVO SSD on the Mid 2010.
The cable arrived. Installed, and booted into the 10.13 bootable install USB and checked Disk Utility. Drive Not there :(
So I tried terminal, and:
diskutil list
And the drive was shown as disk0 500GB SSD!
Launching Disk Utility again the Samsung 860 EVO SSD was now listed, and could be erased and partitioned.
Looks like the Mac Mini 2012 SATA Cable did the trick.
Restoring from Time Machine now :)
Hi, I have installed SSD Samsung EVO 860 250 gb to my Mac mini 2010 (NVidia MCP89 AHCI) and also installed 7200 rpm HDD drive to optibay, and got an issue: SSD works only on SATA I speed (1,5 Gigabit).
After some investigation, I swapped them: SSD connected to optibay, and HDD - to hdd interface. VOILA! 3 Gbs both. Hope, it will help to some body. Old native 5400 HDD gave 40 mbs speed, new 7200 HDD gave 140 mbs speed and SDD gave 260 mbs speed.
OS - El Capitan.
I had change the optical drive with an SSD M4, on my Mac Mini 2010. I kept the original HDD for storage drive, as the SSD is only 256gb.
To be honest I didn’t notice any difference, I was hoping Mac mini has a huge difference. well that was about 3-4 years ago. Now I’m thinking to replace the SSD with an Samsung Evo860 1TB. it worth the risk? I mean I read that the Evo860 is faster than the M4, which is very old model, but I will any extra cable for doing that?
I will put the new SSD to optical drive. Is any difference if I put the SSD on optical drive or on HDD original place?
Hi guys! I'm trying to restore my old Mac Mini Mid 2010 and the SATA cable is damaged and I searched for an original replacement but I couldn’t find it. Can I buy a Mac Mini 2012 SATA cable and connect an HDD without problems? I just want to be sure. Thanks!
Rob crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 64
crwdns2942667:0crwdne2942667:0 14,226
