Solder lightning connector car charger
is it possible to weld the lightning connector of the following charger for iphone 5?
Hi @piero90
WARNING, please do not directly solder and use it.
Cigarette adapter in cars output mostly is 12V
https://www.nonda.co/blogs/news/13486157...
USB uses 5V.... direct 12V can kill your devices
If you see the USB 2.0 wire layout.... there are four cables vcc, d-, d+, gnd
https://www.chipworks.com/about-chipwork...
I would suggest you to get a cigarette adapter to USB charger as it has been converted to 5V and USB standards. You only need to get MFI certified lightning cables to charge your apple devices.
ITS BERY GOOD TO KNOW HOW TO DIY BECAUSE MABE YOU MIGHT HAVE JUST A LOT OF DIFFERENT PIECES OF THIS AND THAT BBUT YOU MAY HAVE A. Part you need IN & .B. A DIFFERENT PART YOU NEED OUT. BUT ALL YOU NEED TO KNOW HOW TO PUT UT TOGETHER THE RITE WAY WITH OUT ANY INJURIES. OR GETTING HURT IN ANY KIND OF WAY…
is it possible to reconnect the cable to the lightning connector that has come off?
Hi @piero90
Give you an idea what is inside,
https://www.youtube.com/watch?v=kjEBbGWg...
but as commented earlier, do not connect or solder it directly to use in direct to the cigarette adapter.
How can I fix it?
https://thewirecutter.com/reviews/best-u...
Get this and put in your car, get a new USB lighting cable.
So I can’t repair it.
crwdns2942667:0crwdne2942667:0 1,004
