Where can I get a CleanForce CF1800 HD repair manual?
Where can I get a CleanGorce CF1800 HD repair manual?
There is none. I had to trash mine and buy another. I believe my unit had a bad internal termistor because it would cut off like it was overheating after only a brief use, then allow me to restart after several minutes. This time I went with a 2000 psi RYOBI from Home Depot.
I had the exact problem you mentioned. I finally did the same thing you did. I trashed the CleanForce and replaced it with a different washer. Thank you for your response.
crwdns2942667:0crwdne2942667:0 569
