iPod screen responsive, but not visible?
So a while ago my ipods touchscreen began to lose its brightness. I figured i could just turn it up again later, however one day the screen just went totally blank. I mean gone. However, if i was to press down where the buttons would appear (such as the double tap and hit play in the top center) The ipod would still work! i could shuffle through all the songs normally. I cannot take it back to the apple store because my warranty has expired. I have not dropped this ipod but i did use it pretty much nonstop. Im thankful that i can still play music on it, but without the ability to pick and choose songs at will, or even play my apps anymore it feels like i'm lugging a large ipod shuffle around. Any help would be great. :)
Short description for those who don't want to read all that: Screen blank; still responsive if you remember where buttons appear.
crwdns2889612:0crwdne2889612:0 -1
You may need to buy a new display, however there is still a possibility that the display cable could have been disconnected, especially if you have dropped your iPod. Go to this guide:iPod Touch 1st Generation Display Replacement At step eight, make sure that the connector is secure to the board, if not then you will need a new display.
Since the backlight of your iPod is integrated into the LCD you will probably have to replace the LCD, but the part that powers the LCD is the inverter circuitry that powers the backlight and it is part of the logic board. So start of with the LCD and take it from there. good luck
Its most likely a burnt out backlight. However your probably going to have to replace the screen itself. So if its worth $52 then go for it! Good luck.
Jack crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 1,716
