1998 Chevy high beams not working
My high beams aren’t working on my 1998 Chevy 1500!!!! Please help
Hi,
Check that your dimmer switch is OK. It changes the feed between the low and high beams
If it is the problem then here's a link to just one supplier where you can search for your exact vehicle model (C1500? K1500?) dimmer switch part number.
There are other suppliers online this is just to show you what the cost may be.
When switched to high beam on switch it doesnt show the blue high beam light on the dash
Hi,
If the dash high beam indicator light doesn't come on and the high beam headlights also don't come on it points to a problem with the switch or perhaps the wiring connector to the switch
My 1997 Chevy Silverado is doing the same thing . So witch switch do I need to change out ?
My high beams is not working and it doesn't even show the indicate light all I have working is the automatic low beam lights and every other light on the truck works accept the high beams
Austinfarmer 1 did you ever figure out the problem? My 97 has done the same thing since I bought it
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 8,553
