1 channel from the stereo is playing poorly, the others are fine.
I have a LCF600UR stereo installed in my car. it has 4 auxiliary outputs, 2 for front(L&R), and 2 for rear(subw L&R) the front channels go to a speaker amp, and the rear to a subw amp. I know the lines are not the problem, as i have tried with other stereos and then everything worked. The 2 channels for rear works perfectly, while only the front left channel works, the front right channel plays at a really low volume.
This problem only occurs when I run the system through AUX cable, when playing CDs all the channels play.
Hi @alfredpennywo
You had mentioned that playing CD were fine, how about others like FM / AM and USB?
Are they working well?
Are you using a 3.5mm audio cable to feed to your AUX?
try using another cable and see if it helps.
You can try this too... sometimes the Car Audio Audio Jack Plug might be busted, e.g. when the music is playing try wrigging or e.g. bending or pushing to right and left till the sound is restored.
If it works, you will need to replace the audio jack.
