Released September 22, 2017. Model A1864, A1897. Available as GSM or CDMA, 64 or 256 GB Storage Options, and the color options are gold, silver, and space gray.
crwdns2934591:0678crwdne2934591:0 crwdns2934593:0crwdne2934593:0
iPhone 8+ Camera bump/glass complete replacement...not just the glass
I bought a camera glass replacement off ebay and it is the entrie "bump"with the glass. All the videos just show the glass replacement. The replacement piece is just one solid piece and looks like it would be an easy pop out, pop it in procedure. I can get a razor blade under the bump, but can't get it to come out, even with heat. Any way to do this or is it glued down?? Thanks!
The camera bump is part of the body. You don't want to try and pry it apart. The new body your order should have the proper camera bump.
1. Do not order a new body as it will give you signal issues with cellular and wifi
2. It is very difficult to change the camera lense with the metal frame as you will need to open the screen and disassemble all components in back camera area.
3. You will also risk scratching the glass back of the iphone 8.
4. you should replace the glass only of the camera lense as it is the easiest option.
John Smith crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 889
