This is the first generation of the Ford Escape, a compact crossover SUV. Production started in 2000 for the 2001 model year.
Head lights work but no low beams
2002 Ford Escape. Hi beams are the only thing that work. Low beams don't. I have changed bulbs and fuses, and switch. Is there a way to find the hi beams until I can figure out what's wrong and fix it?
So either the light switch is bad or you may have a damaged wire. I would start using a volt meter to see if your getting power from the switch first then if that's okay start looking for a bad wire. Have you tested the bulbs to make sure they work. Using a jumper wire to the low beam wire to the battery will be an easy test to see the lights work
Tracie Anne crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 360
