Guides for the LTE version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, originally known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Can anyone please you help me with my ipad display?
The 1/4 th part of my i pad is working great but the remaining 3/4 is having small gey lines and some flikering .
the screen is not broken at all
Should i have to replace my screen or is this because the components are not intact.
Can anyone please suggest the best way in which I can repair it.
Please help !
[http://|https://drive.google.com/file/d/0B8nrv2Q...]
Look like a bad connection, but if you have never replaced the screen there should be no reason it is not seated right. The LCD panel may be damaged, from anything. They are very fragile.
Here is the LCD for iPad Mini 2
new adhesive for the digitizer click Here
If you crack your digitizer getting it off or want to buy a new one just in-case you can get that Here
But it could be that the LCD connector is not seated right, open the iPad and check that it is fully seated before you order parts. But you will need new adhesive if you do open it.
Hope this helped you, keep us updated.
Cheers
Noah
crwdns2886500:0Replace a screen digitizer compatible with the 1st or 2nd gen iPad mini models A1432, A1454, A1455, A1489, A1490. Part #820-3291-A, 821-3291. Home Button and Digitizer Cable included.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
iPad mini 1/2 Screen Digitizer
$34.99
crwdns2886500:0Replace the custom cut adhesive strips that secures the front panel to the case compatible with the 1st or 2nd generation iPad mini model #A1432, A1454, A1455, A1489, A1490.crwdne2886500:0
iPad mini & mini 2 Adhesive Strips
$6.99
crwdns2886500:0Replace a 7.9" LCD Panel compatible with the A1489 and A1490 iPad mini 2 or the A1599 and A1600 iPad mini 3 tablets. Part #821-1805. 2048 x 1536 pixel (326 ppi).crwdne2886500:0
iPad mini 2/3 LCD
$69.99
dinesh reddy crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 104
