Backup camera washer doesn’t work.
My backup camera washer spits out low volume low pressure windshield fluid. I tried cleaning out sprayer hole but am thinking more that it may be a break in the line or at one of the fittings. Problem is trying to get the spoiler or the Camara module off without trim damage seems unlikely. Any thoughts?
Hi,
Don't know your vehicle but could it be the washer pump that is faulty.
Can you access the pump at all? (usually they're at the bottom of the washer fluid reservoir and a PITA to get at)
If you can, disconnect the hose and check the pressure coming directly out of the pump.
If it's OK at least you'll have eliminated this as a possibility.
Just a thought.
