7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
How do I fix my ipad power button?
My ipad power button is jammed. I tried to press it to shut it down, but it wouldnt push. So I held the home button, and volume button so it would restart. It did, but since my power button is jammed in, it keeps restarting. It wont stop. How do I unstick the button?
Are there visible dents around the button?
It's possible you could get the button to pop out if you LIGHTLY bang the edge of the pad against a surface with the button pointing down. If there's any side surface of the button showing you could also try trying to pop it up with a knife point or fine screwdriver.
Yes there are many dents around the button, and a few on it too. Ive tried both of those things, even with finer edged objects but it wont budge.
I have to agree with Skiller. It'll have to be repaired from the inside.
I hate to say it, but you have to take the digi and LCD off to get the dents out. If you go this route use a file to file the inside of the frame where the power button is or try a using a flat head screw driver with a hammer to bend it back out.
However, I have seen the power buttons and other buttons stick because of soda spilled on it. Then again you would have to take it apart and clean it.
Beatris Flancy crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 63
