Repair guides and support for a wide range of Vespa scooters.
2015 Vespa Primavera 150
My wife rides a 2015 Vespa Primavera 150. Over the winter the battery went dead and will not hold a charge. Is there a battery upgrade from the standard acid battery? Like lithium ion or any other that you can think of?
@americancj7 no because the charging circuitry would have to be different. In your case for now I'd replace the battery with a new one. It is most likely shorted out and thus does not hold a charge. If you are really handy you could most certainly build one out of capacitors but this will depend on your abilities and potentials to getting the right parts.
If replacing the battery dosen’t solve your problem then you could have a problem with the voltage regulator if your battery dosen’t hold charge. Try to see if that is not faulty and replace it.
Tyler crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 647
