Portable Bluetooth Speaker with 14 hour playtime. IPX7 waterproof certified. Shockproof rubber exterior. 1800mAh power bank. Released in 2015.
Can I replace the battery?
Battery appears to have died, can I replace it, if so where to source the new battery?
Try checking out the Braven BRV-1s repair page: Braven BRV-1s
The repair page doesn't seem to show where the battery is located, but there should be some numbers on the battery inside and you should be able to find a suitable replacement based off that information. Be very careful when working around lithium-ion batteries. Do not short the leads of the battery, you can get hurt. Avoid puncturing the battery in any way, so open the device very carefully. It looks like the BRV-1s is pretty well sealed together, so be careful during the disassembly. Good luck!
Andi Lusty crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,022
