From the Inspiron series 15 model 5558 released in 2015 by Dell. A mid-level laptop with a 15.6-inch display and fifth generation Intel processor.
Can we use USB for Garphics card storage Improvment?
Can we use external USB drive to increase graphic card memory? to get faster experience, I'm Interior Designer and generally using for Interior view rendering with vray Can I speedup with my USB drive to increase storage of graphics?
Hi,
No.
Here's how ReadyBoost works to help system memory not video memory.
Check how much system memory you can assign to video memory. (Graphics properties > Advanced Settings > Shared system Memory)
It is not likely that you can increase your Graphics memory. However, you could increase your system memory, which would result in better overall performance. For example, increasing your system memory would speed things up when you regenerate a drawing. But in order to achieve this speed improvement, you will need to use actual memory, not a USB drive which is acting like memory.
If you currently don't have enough memory, you will sometimes have bottlenecks ("traffic jams"), slowing everything down. In this case, anything which will alleviate the bottleneck will help. This is the one case where using a USB drive as memory will speed up your system. But since USB is a lot slower than actual memory, you would be a lot better off by adding actual memory to your system rather than by using a USB drive as memory.
Sandeep Patel crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 256
