The Nintendo Switch is a handheld game console that can be played on the TV via a docking station, or on the go. Released March 3rd, 2017.
crwdns2934591:0704crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Strip screws? How to fix?
Hi i screwup my side console, by stripping one of the screws. ( i used a y00 instead of a y000). Rubber band and super glue didnt work. To remove glue i use a drill bit (1mm), now there is a counter sunk hole. Ideas?
crwdns2889612:0crwdne2889612:0 8
Sounds like you already have drilled a hole there so I would just get the next biggest drill bit and drill it more. You might even need to use the next biggest bit after that. Once you drill the head off then you can usually take it apart more until you can get to the screw and use pliers to turn it out.
Hope this makes sense.
crwdns2889612:0crwdne2889612:0 7
Try this
Precision Screw Extractor Set
crwdns2886500:0Precision Screw Extractor Setcrwdne2886500:0
crwdns2934075:0crwdne2934075:0
$24.99
Welp.. Y00 is correct you might have presed a lot. Y00 works for me
So how was this problem solved? I have the same situation. Please help.
crwdns2942205:01crwdne2942205:0:
Have you tried How to Remove a Stripped Screw already?
Needle nose pliers is what worked for me
jonathan ambrose crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 25
crwdns2936753:030crwdne2936753:0 143
crwdns2942667:0crwdne2942667:0 32,103
