The sedan version of the compact Toyota known as the Echo, Yaris, or Platz depending on the market. The hatchback version of the Echo/Yaris is known as the Toyota Vitz.
2005 Toyota Echo parking brake adjustment
How to adjust the parking brake on my 2005 toyota echo?
joe blow follow this from the SM:
PARKING BRAKE LEVER
ON-VEHICLE INSPECTION
1. CHECK PARKING BRAKE LEVER TRAVEL
Pull the parking brake lever all the way up, and count the number of clicks.
Parking brake lever travel at 196 N (20 kgf, 44.1 lbf):
6 - 9 clicks
If incorrect, adjust the parking brake.
2. IF NECESSARY, ADJUST PARKING BRAKE
HINT:
Before adjusting the parking brake, make sure that the rear brake shoe clearance has been adjusted.
For shoe clearance adjustment, see page BR-31 .
(a) Remove the console box.
(b) Loosen the lock nut and turn the adjusting nut until the lever travel is correct.
(c) Tighten the lock nut.
Torque: 5.4 N·m (55 kgf·cm, 48 in.·lbf)
(d) Install the console box.
joe blow crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,582
