How to fix a broken fairy lights
Hello,
I have a fariylight string which was working with a solar panel, however it stopped working suddenly, I don't know why, I opened it, and there is a battery that gets charged and then is used to supply the lights,
now what I want to do is, remove the solar panel and directly connect the lights to the battery,
I tried that, now I have two wires from the light, I connect either of them to the battery but it won't work, I used a tiny resistor from another device but it won't work too.
I watched a video where I can connect the two wires to a usb but it didn't work too.
I don't know if there's something wrong in the way I do it. I don't know if there is a positive wire and negative one but I've tried both and it won't work.
what should I do? and know that I've got no experience at all in electronics but I'm trying to.
Clean or bypass the on/off switch if there is one. Clean the battery terminals. More detail is on youtube now. You can test it with a regular battery. Just don’t get light on the solar panel.
Atheee crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 95
crwdns2942667:0crwdne2942667:0 3,358
