Released in June 2017 as a successor to the Surface Pro 4. Also known as Microsoft Surface Pro 12.3". Model number: FJT-00001.
Heat Gun/Blower for Screen Replacement
I am looking at purchasing a heat/gun blower to replace my Surface pro 5 screen (warm the adhesive to weaken it)....as well as for other electronics.
I have come across 3-in-1 Function Heat Blower and Soldering Iron (see link below), which I thought could be helpful with other projects also.
https://www.jaycar.co.nz/3-in-1-function...
Has anyone had any experience using this type of "heat blower"? First thought is it may be difficult to control the temperature...although it does have a flame adjustment setting.
Thanks in advance for your help.
Hi @dgmossman ,
You may wish to take note of the warning at Step.1 in the ifixit Microsoft Surface Pro 5 Screen Replacement guide.
Just a thought.
Go for an iopener, otherwise it's too easy to damage the surface.
I think the soldering gun you picked will be to narrow an area and far to hot to do the job well. I believe you chances or success on this repair would be much greater with a standard heat gun:
Heat Gun
crwdns2886500:0Loosen adhesive or reflow solder with this 1500W heat gun. Low setting reaches 570 degrees F (300 degrees C). High setting reaches 1112 degrees F (600 degrees C).crwdne2886500:0
crwdns2934075:0crwdne2934075:0
Heat Gun
$29.99
I would use the iOpener or a heatmat.
Daniel Mossman crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,617
