Why has my reverse camera stopped showing a picture?
When I put the car in reverse, the dash display shows the electronic grid, but is no longer showing a picture of the back of the car and what is behind the car.
Hi Bill, I had the same problem, and after a month the grid also did not apear anymore, It is caused by moised in the camera , (and a fuse ) The solution is a new camera, however not the Original camera (this costs 250 dollar) you can order a camera at WISH €11,- and solder it on the connector wich came from your old camera.
I made pictures of the wirring so if you need futher instructions let me know
Hello, i would like to apologise for my english in the first (not my birth language). I was searching for some answers about faulty backup camera. I woudl like to ask you, what camera did you buy from wish or another website? I have kia optima 2012 and there is plenty of them. Could you recommend any? Thanks, Petr.
Usually, it’s moisture that got into the camera sensor. You can try pulling it off the car, taking it apart, drying it out with a hair dryer or similar device (heat gun, air dry, etc.).
I had this problem and wasn’t able to fix mine, so I purchased a replacement at rockauto.com
where's this camera sensor located, please?
crwdns2942667:0crwdne2942667:0 3,346
