The Chrysler PT Cruiser is a front-engine, front wheel drive, small family car/Compact MPV manufactured and marketed internationally by Chrysler in 5-door hatchback (2000–2010) and 2-door convertible (2005-2008) body styles.
2007 PT cruiser touring Where are the drain holes located?
Hi guys OK I am having an issue with my PT cruiser touring 2007.
I think its getting wet somewhere as the problem seems to be worse after it rains or during.
All the dash warning lights come on then they go off leaving the seat belt warning light on there it bongs 3 times then goes off then all the dials speedo temp & fuel all go off then come back on again occasionally the engine cuts out & I have to stop put it into park & turn ignition on which fires up straight away.
This is starting to happen more & more someone suggested it could be the drain holes could be blocked & its leaking onto the electrics somehow & causing this issue.
I think I have located the drain holes at either side of the car on the front which were just under the windscreen wipers reservoir both had about an inch of mud in them which I have cleaned one side when I pour water from a watering can down comes out of a small hole inside the wheel arch but the other it tricks out of the same hole but most of it comes out from behind the plastic cover in the wheel arch.
There is also a small hole central under windscreen wipers which seems to be running freely but whether this has anything to do with my issue remain to be seen.
Are they the drain holes or am I looking in the wrong place if so where should I be looking also what do you guys suggest I could use to unblock them please?
Any help or suggestions greatly appreciated.
Thank you in advance
Heres a quick video of the issue
Kenny Leonard crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,457
