The LG Stylo 3 Plus is an Android smartphone released in 2017 by T-Mobile. It features a 5.7-inch HD display, 32 GB of storage, and runs the Android 7 OS.
Is the stylo 3 screen made all together?
Is the stylo 3 screen made all together or can I just replace the main glass on without having to replace the lcd too? Nothing is wrong with the touch of the screen just dropped it and cracked the glass screen.
crwdns2933315:06crwdne2933315:0
You can get the screen assembly or you can get just the glass. I would highly recommend you get the assembly because just replacing the glass requires patience, steady hands, constant, liquid optical clear adhesive, and a UV light. Although the glass is significantly cheaper, there is a very large possibility that during the glass removal process, the LCD will crack.
Parts for the screen assembly run around $30-$40
The glass only you can get for around $5 but you will be needing the tools to remove the old glass and replace/cure the new one.
How do I know which is the right assembly to get? Lol new to all this everywhere Ive found what 100+ to fix it.
now worries, can you send me the model number? You should be able to take the back battery cover off, take the battery out, then look on the sticker that sits under the battery. Should be some lettering that tells you the model number.
LG-M430 is the model number
Here is your part. This is the best I could find without going to places like eBay. Places that sell just phone parts are in my opinion better to go with. https://www.repairpartsplus.com/LG-Stylo...
Yes the screen (glass) itself can be replaces seperate from the phones frame, digitizer, etc...
BUT, you can spend the $17 or so for the glass and run into what I have saw commented on that no glue is included with the screen only kits and risk breaking the glass through this intensive repair. Or get an entire OEM LCD + digitizer in its frame starting at $37 on aliexpress.com or like mine $45 @ Ebay.
Repair here locally (Atlanta, GA) quoted me $100-$120 over 3 seperate repair quotes so @ $45 I'm in by less than 1/2 price of paying for repair and still less than 1/2 replacing this phone with another like model!!!
Will a lg stylo 3 plus touchscreen digitizer fit on a lg stylo 3?
yes it does but sometimes it comes on the digitizer without side rails and volume button.
Your glass is broken it sounds like, and you really only need the glass not digitizer or lcd. But…it will be easier to replacec all 3 they come glued together with adhesive so changing glass requires some skill and tools. Check ebay, for a used oem replacement screen.
I need some one to fix my phone screen
Emily Mize crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 2,586
