JBL Flip 4 portable speaker. IPX7 waterproof bluetooth dual driver speaker that won the CES Innovation Award 2017.
Not charging or turning on
My JBL speaker has been working fine and now nothing lights up even when it’s plugged in. I’ve used 3 diffrent cables to try and charge it with they don’t make a difference. Nothing has worked and it makes me sad. I’ve tried resetting it and again nothing happened, so I don’t know what to do.
crwdns2944067:04crwdne2944067:0
i fixed it,
you have to put
pressure on the flat cable that is connected with the "power button/LED/ JBL Connect Chip". Then you have to put a cable back in the usb chip
after that it should work again
And how do you do that?
all of you are wrong!!!,
Did you check the 5v on the usb type v8 line?
Did you check the 5v on the usb board?
Did you check the 5v get to IC charging?
Did you check the 5v get to Batery?
Did you check the 3.3v & 2.7v & 1.2v to the PMIC?
how do i check all these? is there a kind of tutorial?
If your JBL Flip 4 speaker refuses to turn on, see the JBL Flip 4 Won’t Turn On problem page for possible causes and solutions.
If your JBL Flip 4 speaker will not charge or won’t hold a charge, see the JBL Flip 4 Will Not Charge Or Won’t Hold a Charge problem page for possible causes and solutions.
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Abigail J Rhea crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 3,463
