Guides and support for various television (TV) brands and styles.
crwdns2934591:09058crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Bush TV stopped working - No power
Hi everyone,
My Bush TV (LED24127FHDDVD) randomly turned itself off with no indication of any problems prior to it happening. I've had it a couple of years and not had any problems whatsoever.
Usually the standby light turns on when it is plugged in but that doesn't even appear anymore.
I've replaced the fuse in the plug but that did not make any difference. I'm assuming it may be a problem with power but I am not entirely sure.
I have attached pictures of the circuit board at the back of the TV- any help in the matter would be greatly appreciated.
My Bush lcd32tv016HD 2007 vintage, kept turning off with no standby light. I fixed it by viewing the power board soldering with a x10 hand lens and found lots of cracked solder joints. With a soldering iron, solder and flux, the solder can be melted to repair the joint. Also did this on the logic board where the power comes in. Basically anywhere where there is lots of heating and cooling, the solder eventually breaks either at connections or hot chip. Also replaced an electrolytic iffy capacitor (smd 10uF 16v esr38Ohm) but not sure if that was necessary.
crwdns2942205:01crwdne2942205:0:
How to repair cold solder joints
https://www.youtube.com/watch?v=VLubdi6a...
Tester1331 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 6,579
