Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Pinout for Charing port
Hey all does anyone have a pin out of the usb charging port on the Ipad Mini 2?
https://s19.postimg.org/6t657c3jn/Screen...
Is this on logic board?, if the pin is missing u need scratch, to make new pin
i dont even know what pin(s) are needed - thats what i need to find out.
Here is a image that shows where you have to connect the missing pad. Look for the red :>)
So the red dot is also power from the usb connector since it seems I'm missing those 2 red pins?
Also, what would the ground be located?
To find ground, just put one multimeter probe on a shield and then use the other probe to check the pins individually. Then look for 0 Ohm readings or a beep in continuity mode.
Thanks @Minho. This pin for power would be the one that allows it to be charged as well, correct?
David crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 497
