An all-new Passat, based on the Volkswagen Group B5 platform, was launched in 1998 in North America.
Car is hard starting
My 2001 Volkswagen Passat 1.8t is hard starting when hot or cold and I have to crank over the engine and turn the key off and try again and again before it will start. When it does start it usually idles really low until it finally catches up to normal.
This question was migrated from https://meta.ifixit.com/Answers.
Even though it does sound a lot like a Fuel pump/fuel pressure issue. Get your car scanned just in case. Fuel pump won't throw a code though.
When you have the codes and aren't sure, post back here.
Air flow and throttle show a short circuit .wiring okay
check your fuel pump in case fuel is not pumping. In case, it's not fuel pump, check the fuel filter if its not that then it is starting sensor. these are the three likely suggestions for the hard starting in VW passat.
Stephen Ryan Bearden Madison E crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,452
