2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache and an optional AMD Radeon R9 M370X dGPU.
Is the iFixit adhesive remover just isopropyl alcohol?
I am thinking about doing a keyboard replacement for my MacBook Pro but the battery must be pried off first. Instead of forcing it off, I found the adhesive remover in the store, but I’m hesitant to spend $33 for a solution that is similar to alcohol.
Has anything else worked for anyone?
crwdns2933315:06crwdne2933315:0
Hi @davchun
Watch the provided link and at 8 Second, pause,
https://www.youtube.com/watch?v=8krNjKEs...
It mentions contain Acetone
, etc almond fragrance....
crwdns2889612:0crwdne2889612:0 8
Check out aldon-chem website and search for sds, or google “aldon chem sds”. Chemical name “AA-0051”. The sds says it’s 99.8% acetone, 0.1% Cherry Almond Fragrance and 0.1% FD&C Blue #1 (C.I. No. 42090). It’s all public information.
I went to Walgreens and get 100% acetone nail polish remover. It works
I started using pure methanol a couple of years before iFixit found a solution.
I am thinking of replacing my macbook pro battery. Hesitant to buy an adhesive remover. But wouldn’t the acetone/nail polish remover damage or erode the old battery and causing problems?? I mean the old battery should be pretty fragile, I suppose..
[image|1948870]
yeah just go buy acetone lol
Acetone might affect the plastic covering but the actual battery cells are encased in metal. Acetone should be ok but I'd avoid nitric acid.
I replaced a battery just now and tried isopropyl alcohol (100%) on one side and acetone on the other side. I didn't find a lot of difference in how they removed the glue and I can say that both solvents struggled to dissolve it.
Is it just Concentrated Windshield Washer Solvent with Ammonia?
crwdns2889612:0crwdne2889612:0 -1
google aldon chem sds and search for AA0051. it's a mix of acetone, fragrance and blue dye.
David Chun crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 127
crwdns2942667:0crwdne2942667:0 17,883
