Hello Jodi,
I am sorry that you wasted money buying the wrong boards for your tv. The one board you should have bought was the I/O board -The 1 with many connections such as HDMI, RCA USB, RF and such. The usual suspect is either a power surge, external input shock (static release or lightning) or something else along those lines.
Good Luck!
Rich lilja
Hello Jodi,
This may sound strange, but did you try other input sources such a dvd player, a VCR, or another cable box? Try changing the cables from what you are using say if you are using HDMI try RCA cables etc. Perhaps the cable box is defective or needs to be rebooted. Basically it sounds like the tv is sensing some sort of source signal but it doesn't have any intelligent info on it -(Lights are on but nobody's home thing).
That should help!
-Rich Lilja
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
0
crwdns2944067:07crwdne2944067:0
Isn't that also called the main board? The tv is a samsung un50h5203afxza version nh03.
crwdns2934271:0crwdnd2934271:0 Jodi crwdne2934271:0
I have a Samsung UN50J6200 AFXZA LED tv and same issue. While watching tv, blue screen appeared, audio works fine. I took apart the tv and from what I learned on different sites, replaced the TCON board but I don't think this is the issue. I've tried both the HDMI ports and the Audio and Video jacks with a DVD player and Wii console and audio works perfectly but the screen is just blue. Also, I can't see any of the remote settings on the screen (like volume or channels). Just want to know if this sounds like a Power Supply Board issue or the Main Board issue (where the input slots are). Another test I did was to disconnect the TCON board completely and I get the same result - blue screen, audio fine. There are two ribbons that exit the TCON and connect to another small board on the bottom of the TV. What are these called? I wonder if those would be the issue?? Any help would be great!
crwdns2934271:0crwdnd2934271:0 Lisa crwdne2934271:0
It's the backlight. Have the same problem
crwdns2934271:0crwdnd2934271:0 Christof Geraerts crwdne2934271:0
I have a samsung model#UN55J6201AF and my tv screen is blue and I don't know what to do about
crwdns2934271:0crwdnd2934271:0 Jeffery Ransom crwdne2934271:0
Did you have any luck? I have a Samsung UN60eh6050fxfza, blue screen nothing else. Audio works perfectly, tried av cables as well didn’t change. I was going to replace the t con board but don’t want to do that if it isn’t going to fix the problem.
crwdns2934271:0crwdnd2934271:0 Kristen Todd crwdne2934271:0
crwdns2934275:02crwdne2934275:0
