Why is the fan so loud?
https://www.youtube.com/watch?v=zlUD997F...
No damage on the fan. Computer seems to work fine.
Uh, so apparently the fix was much simpler than opening it up and dealing with hardware. I just used a paperclip and pushed the little pinhole button underneath the laptop to reset the battery, then plugged it into the charger. It started up with no issue, no more loud noise.
@michael5029 there may not be any visible damage but if you look carefully at your fanblade you see that there is a variation in fan speed. This may be caused by the fan itself as well as the tachometer on the motherboard. I'd replace the fan and re-evaluate before trying anything else.
Hi, is it possible that something in the bios could be causing it as well? Also what would I have to do if the tachometer was causing the problem?
that does not sound a like a BIOS issue. If it would have to do with your tachometer then you would need to find a schematic and go through the circuitry. Start with a new fan. The sound coming from your fan is quick and rhythmic to rule it out.
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 1,769
