The HP G62 is a laptop series produced by HP. G62 laptops are identifiable by the model number G62-XXX-XX, and endings vary depending on options and seller.
Change Hard disk broken
My laptop is HP G62-452SL. I have to change the broken HD.
Which parameters do I have to know?
How can I change hard disk?
Tanks
Hi @giomun ,
Here is a link to the service manual for your laptop. Scroll to p.42 to view the necessary pre-requisite steps and then the procedure to remove the HDD. Just reverse the procedure to install the new HDD.
Also on p.42 you will find the part numbers for HDDs for the laptop. You may wish to consider installing a SSD instead so as to improve performance.
Try various sites such as here and here (select your exact model number in the model box) to see if this option interests you or not.
Usually the BIOS setting is for automatic HDD detection so you shouldn't have to make any changes to the settings in the BIOS.
Giomun crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 221
